It is currently Thu Jul 17, 2025 6:23 pm
 Post subject: Neck dents help....
PostPosted: Sat Oct 21, 2017 1:22 pm
Got a new guitar I made come back after 3 weeks with 6/7 small dents half way along the back of the neck where it's been bumped against something.
He says they've been there since he got it back home, and I'm not going to argue whether they were there when he picked it up or not (I don't remember seeing any when I was doing final setup just before pickup, and he's fitted new tuners and a K & K since)
Finish is Enduro-Var (several good layers), well cured, and the dents are very shallow and small, but you can feel and see them.
I think the neck (bolt on) has to come off for finish removal, steaming the dents (mahogany) out as much as possible, complete sanding and more or less a complete re-spray before refitting.
Anyone got any better/different suggestions or helpful advice?
 Post subject: Re: Neck dents help....
PostPosted: Sat Oct 21, 2017 3:23 pm
Hey Colin, sorry to hear about the glue withdrawal....;). Kidding of course. :)
I have a hunch that steaming with a wet rag against a dent and the flat paddle that comes with some Weller soldering guns might swell small dents through the varnish. I've done this with success if the dents are shallow.
It's place the hot paddle against the rag, wet on the dent, count a few seconds, remove the heat and repeat half a dozen times or so with waiting a minute in between sessions to let some swelling happen.
Since your plan is to remove the neck and refinish anyway what do you have to lose?
Good luck with the withdrawal, I plan of sleeping better tonight too. :)
PostPosted: Sat Oct 21, 2017 4:02 pm
May give it a try Hesh, as you say, nothing to lose. Itl be a bottle cap or spatula, rag and soldering iron if I do, no weller gun/paddle.
Hope you sleep better tonight, sweet dreams!
These users thanked the author Colin North for the post: Hesh (Sun Oct 22, 2017 5:30 am)
PostPosted: Sat Oct 21, 2017 5:35 pm
Guy married?
PostPosted: Sat Oct 21, 2017 6:18 pm
Yup
PostPosted: Sun Oct 22, 2017 7:27 am
Wedding rings are cruel to necks...
These users thanked the author Haans for the post: SteveCourtright (Tue Oct 24, 2017 12:56 pm)
PostPosted: Sun Oct 22, 2017 10:10 am
laughing6-hehe
These users thanked the author Colin North for the post: Hesh (Sun Oct 22, 2017 6:41 pm)
PostPosted: Sun Oct 22, 2017 4:09 pm
First name: george
Last Name: s
Haans. I had a Kalamazoo with the finish all chipped on the rim below the neck joint, no other place. I could not figure out what caused it until I was playing, and slid up the neck and - BANG, hit it with my wedding ring. It happens :-) Thanks.
GS
Sent from my SM-G950U1 using Tapatalk
PostPosted: Sun Oct 22, 2017 5:02 pm
So the bad (and good) news is that cured Enduro Var seems completely impermeable to steam.
PostPosted: Mon Oct 23, 2017 12:00 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Use a push pin to break the finish in the dents, and add drops of water. It might swell on it's own, or might need some heat. Any way you do it, there's going to be a bit of finish repair needed.
Alex
PostPosted: Mon Oct 23, 2017 12:31 pm
Alex, thanks for the suggestion, but I'm sure cured Enduro Var will show witness lines, especially a satin finish - no chance of buffing them out, even if gloss might.
Neck's off and it will get a strip and refinish
PostPosted: Mon Oct 23, 2017 3:40 pm
First name: Alex
Last Name: Kleon
City: Whitby
I've used EnduroVar for 5-6 kitchens, so far. I'll give it a try for guitar finish if I can get a break from cabinetry this winter. I'll be picking your brain for satin spraying, Colin!
Alex
PostPosted: Mon Oct 23, 2017 3:52 pm
Alex
If you can find them, you're welcome!
